" /> CCpulse Version 7.2.001.03 - Virtual agent group question - Genesys CTI User Forum
Author Topic: CCpulse Version 7.2.001.03 - Virtual agent group question  (Read 7830 times)
Offline jsty40
« on: April 28, 2009, 01:26:24 PM »
Been using VAG's to show # of agents logged into each skill.
Works great..but even though when building the views from scratch I always be sure to leave the  "include all agents" underneath the VAGs UNCHECKED..sometime later, days - weeks, agents begin to showup underneath the VAGs in the object pane.  From day one, after building the view, they don't appear under...but somehow they begin to show in the object view sometime later..not sure if has something to do with when Skills are managed...
anyone run into this and have a sure fire way to prevent agents from showing up under VAG objects ?
thanks
Js
tony
Re: CCpulse Version 7.2.001.03 - Virtual agent group question
« Reply #1 on: April 28, 2009, 02:20:17 PM »
It may be version specific - I am running 7.5.001.04 and it has a few more Options for Real-Time Views.
If you are building VAG's ONLY for the View then you should be checking Tenant>Persons>Group of Agents first, then selecting the VAG's on the next screen.  Once you have the View available (with just the VAG's listed), you begin to build a new Template - make sure you are building a new Template based on an Agent [b]Group[/b], not just Agent.  Once you have built your new Template, apply it to the Selected VAG's in the View, in the Objects pane on the left-hand-side....
Within later versions of CCP, it is possible to Create a View based on some different criteria, which may not be available in your version.  In mine, you get the Options to;
Create Real-Time View
Create Real-Time View for Members
Create Real-Time V/AG Dynamic Membership
I'm not sure, since I don't have your version loaded but this may be where your problem is; in the application of a pre-defined View to a VAG.  It may be that you don't have the Option(s) to create a simple View for the VAG Object but rather it automatically "assumes" you want to create a View for all members or for a V/AG dynamic membership.
Can you let me know what Options appear on your version, if you right-click your VAG(s) in the Objects Pane?
There are other areas to explore - such as how Agents are associated with VAG's but I think we can exclude the application and removal of Skills as a factor since we are concerning ourselves with VAG's, not Skills...
Tony
« Last Edit: April 28, 2009, 02:22:33 PM by Tony Tillyer »
Offline jsty40
« Reply #2 on: April 28, 2009, 03:54:32 PM »
Tony,
This version has same options when right click on VAG.
The VAG's are built in CME with script in annex:
Skillname > 0.
if you have the skill x greater than 0, than you dynamically become part of the VAG.
thanks
JS
Offline SisB
« Reply #3 on: April 28, 2009, 08:33:48 PM »
What is the version of CCPulse you are using?
CCPulse has a long history of presenting incorrect VAG membership and reporting data. Please check the release notes or try with latest version and see if the problem still persists.
Offline ecki
« Reply #4 on: April 28, 2009, 09:50:39 PM »
Hi Jsty40
Try set the CCPulse option IgnoreNewObjectNotifications=true in section Workspace.
Though this requires the latest CCPulse version.
e.
Offline jsty40
« Reply #5 on: April 29, 2009, 12:55:40 PM »
Thx, where is ignore new object notifications ?  thats sounds like it would do the trick..is that in the StatServer ?
thanks
js
Offline jsty40
« Reply #6 on: April 29, 2009, 12:58:17 PM »
nevermind I found it in the GUI folder,,the app definition..
thanks,,we don't have the latest clients out there.. but I think thats the solution
thx again
Offline ecki
« Reply #7 on: April 29, 2009, 01:04:58 PM »
Nope, it is a CCPulse option.
[CustomStatistic]
ExtendedCurrentStatus=True
MediaTypes=voice, email
[IconStyle]
DNLoggedOut=7.5
[Storage]
ActionsStorageFullPath=D:\GCTI\CCPulse\Actions.stg
QueryStorageFullPath=D:\GCTI\CCPulse\Queries.xml
TemplatesStorageFullPath=D:\GCTI\CCPulse\Templates.stg
ThresholdsStorageFullPath=D:\GCTI\CCPulse\Thresholds.stg
WorkspacesStorageFullPath=D:\GCTI\CCPulse\Workspaces.stg
[UserInterface]
EnableDNAliases=True
ShowAgentLoginID=True
ShowAgentSkills=True
ShowDurationBeforeStatusName=True
ShowStatusReasons=True
[View]
CurrentStateRefreshInterval=5
DelayBeforeRemoval=15
MaxNumberOfAgents=75
[b][Workspace][/b]
CurrentStateEnable=True
EnableAgentCapacity=True
EnableAgentCapacityStatus=True
EnableAgentGroupCapacity=True
[b]IgnoreNewObjectNotifications=True[/b]
SafeScriptingMode=True
UseStatServerVirtualGroups=True
WorkspaceAutoLoad=True
Check the CCPulse admin guide.
Offline ecki
« Reply #8 on: April 29, 2009, 01:08:01 PM »
Oh, sorry, ;) You were too fast for me.
What version do you have? Probably it could be enough you run any 7.5.x
Offline ecki
« Reply #9 on: April 29, 2009, 01:12:52 PM »
That was really stupid question.  ::)
Well I do read the subject only once.
