" /> Problem to get reports in Hyperium. - Genesys CTI User Forum
Author Topic: Problem to get reports in Hyperium.  (Read 3940 times)
Genesys Rookie
« on: May 14, 2009, 03:26:31 PM »
Hi everyone
I have delay in obtaining the data to get reports in Hyperium even when the DMA reads are Ok.
I see the ETL logs and I donīt find any explication of this.  :-[
this ever happened to anyone?
Genesys Rookie
Re: Problem to get reports in Hyperion.
« Reply #1 on: May 29, 2009, 07:06:02 PM »
  • no body happend that ??
    Offline ecki
    Re: Problem to get reports in Hyperium.
    « Reply #2 on: May 30, 2009, 01:18:08 PM »
  • Hi,
    What is the delay you are talking about and for which aggregation level?
    Usually the ETL is set to transfer data as soon as possible but the aggregation process could be set to be run every hour or even once a day. I would recommend you to check the ETL configuration options.
    e.
    Offline gustav
    « Reply #3 on: June 01, 2009, 03:43:04 PM »
  • More information required.
