" /> Virtual route point - Genesys CTI User Forum
Author Topic: Virtual route point  (Read 6337 times)
Offline kishore
Virtual route point
« on: May 22, 2009, 08:39:04 PM »
I have posted this question b4 and there are few others like CTIgem, cavagnaro, mark, Gui75 who showed intrest on the topic but could not answer this question
http://www.sggu.com/smf/index.php/topic,3998.0.html
[b]Which function do you use to route to VRP?[/b]
could some one let me/us know how to transfer/route call to VRP from RP?
« Last Edit: May 22, 2009, 08:40:56 PM by kishore »
Offline CTIgem
Re: Virtual route point
« Reply #1 on: May 26, 2009, 03:03:54 PM »
So far what I've found is that, you can't use it like real route point meaning transfering voice calls to it.
You use it with GVP with URS, need to have vrp by doc. And other media routing such as email ...etc.
Hope this makes sense.
Offline kishore
« Reply #2 on: May 26, 2009, 04:05:12 PM »
Hi CTIgem,
[quote]You use it with GVP with URS, need to have vrp by doc[/quote]
could you please give an example.
Thanks a lot
« Last Edit: May 26, 2009, 04:07:42 PM by kishore »
Offline Gui75
« Reply #3 on: May 27, 2009, 05:01:36 AM »
Victor and Cavagnaro said it was possible to use VRP for statistic purposes and route from RP to VRP.
WITHOUT using any IVR.
So that if one of them Victor or Cavagnaro could give some more details, we would be so grateful
Offline CTIgem
« Reply #4 on: May 27, 2009, 05:11:45 PM »
I haven't try this so I don't have any examples.
But you would send a call from GVP to some VRP then URS take over control of that call.
Offline JGMG
« Reply #5 on: May 27, 2009, 07:57:17 PM »
VRPs are a mechanism to obtain a target, not to actually move a call.  Its basically asking URS how _Would_ it route the call if it could.
Now, with many IVR systems, the IVR will automatically transfer the call to the target obtained, so the difference may be moot, but you cannot deliver a call to a VRP.
At least to my knowledge.
Offline kowari
« Reply #6 on: May 28, 2009, 03:20:42 AM »
^^ this
They are like a virtual queue, kinda.  So while you are on a VRP you are stil physically located on the original DN that made the route.  It doesnt GO anywhere, it is a logical partition, not a physical one.
So, you might need to clafiry your question as to exactly what you mean.
Offline Gui75
« Reply #7 on: May 28, 2009, 04:24:39 AM »
OK guys,
Taking into account last comments the question is :
When you reside physically in the goold old routing point, how can you (withou using IVR) send to URS a routing request so that URS will execute a strategy on a VRP at the same time.
