" /> UseAgentState - Genesys CTI User Forum
Author Topic: UseAgentState  (Read 4492 times)
Lucy
UseAgentState
« on: June 23, 2009, 06:30:58 AM »
  In URS --> Options--->UseAgentState--> true
URS-->ANNEX --->AgentStates --> ReadyForChat ---> busy[extension]+busy[chat]=0
I want to restrict the agent to have only one interaction at a time. If he is on call ,he wont be getting a chat interaction & if he is on chat he wont get call.
My starategy is like
Start ------> Function block                    ------------->      target block
                  UseAgentState['ReadyForChat']
But this is not working...calls are not getting routed. Kindly correct me if anything is wrong. Or tell me the correct way of doing it.
Thanks in advance....
Offline YevgeniyP
Re: UseAgentState
« Reply #1 on: June 23, 2009, 06:42:06 AM »
Is it 6.x or 7.x?
Lucy
Re: UseAgentState
« Reply #2 on: June 23, 2009, 08:06:21 AM »
It is 7.2.
Lucy
Re: UseAgentState
« Reply #3 on: June 23, 2009, 11:39:02 AM »
I have changed the option
URS ---> OPTIONS---> CheckAgentState --> true
Now the call is getting routed. But the problem is the agent receives both voice and chat. I want to restrict him like when he is on chat he shud not get voice call and when he is on voice he shud not get chat call...
Kindly provide me some pointers...
Thanks...
Marked as best answer by on Today at 08:03:55 AM
Offline kubikle
Re: UseAgentState
« Reply #4 on: June 24, 2009, 12:45:55 AM »
  • Undo Best Answer
  • What is value of option use_agent_capacity?
    Also fragent of router's log can be usefull (where second interaction is going to the agent)
    Re: UseAgentState
    « Reply #5 on: June 24, 2009, 02:58:09 AM »
    Please there are several posts about the same question, search around.
