" /> Install Multimedia - Genesys CTI User Forum
Author Topic: Install Multimedia  (Read 3955 times)
Offline lekie
Install Multimedia
« on: June 29, 2009, 02:54:16 AM »
Dear All,
    Please someone to help me I am installing MM on single server by using wizard and I can start all of the MM application except WEBAPIServer and I have noticed one thing I use Tomcat and IIS. In IIS I cannot see WEBAPI75 floder but I have WEBAPISample75 I don't know how can i make it? I think If I have WEBAPI75 in IIS I can start WEBAPIServer right? I already try to uninstall/install just only WEBAPIServer but still cannot get WEBAPI75 -_-'
Thank you in advance
Lekie
Re: Install Multimedia
« Reply #1 on: June 29, 2009, 03:11:04 AM »
The wizard installation is very detailed on the Deployment guide, have you checked? Check also what your logs says about the error.
Offline lekie
« Reply #2 on: June 29, 2009, 03:46:19 AM »
yes i already check as in document do you have document about implement WEBAPI?
Thank you in advance,
Lekie
Offline lekie
« Reply #3 on: June 29, 2009, 03:53:01 AM »
HI,
I have try to open web test such as http://localhost/WebAPISamples75a/EmailWithAttachment/Email.jsp but the web page has showed [b]source code[/b] of jsp I don't know why?
Regard,
Lekie
« Reply #4 on: June 29, 2009, 06:25:57 AM »
Because you haven't instruct IIS that those formats have to be handled by Tomcat. There is a configuration needed in order to do it, i'm sure it is on the documentation.
Offline lekie
« Reply #5 on: June 30, 2009, 05:33:09 AM »
how can i connect webapi with tomcat in KANA? can i do? i want to used same tomcat because i install co-brow and web-api-server in the same machine.
Lekie
