" /> Statserver LOGIN table - Genesys CTI User Forum
Author Topic: Statserver LOGIN table  (Read 3790 times)
Offline mark
« on: August 10, 2009, 02:20:44 PM »
Afternoon all (morning to those in far off shores!) :D
Yes, I am asking about the statserver LOGIN table, something that has been apparently asked about many times, however, i seem to be blind to the results from search as cant find what I need.....
How do I access the LOGIN table on stat server?
The stat server deployment guide is great in telling me how to activate and what the fields are, but not how to query it? Can I query the table via Hyperion?
Cheers :]
Re: Statserver LOGIN table
« Reply #1 on: August 10, 2009, 02:34:59 PM »
Hi Mark,
Database location is determined by DAP listed on "Connection" tab of StatServer. You can access that table using Hyperion or any other tool that can work with DBMS used by Genesys (StatServer).
Offline mark
« Reply #2 on: August 10, 2009, 02:54:30 PM »
Excellent, thanks René
