" /> datamart - Genesys CTI User Forum
Author Topic: datamart  (Read 3200 times)
Offline lekie
datamart
« on: August 26, 2009, 09:31:27 AM »
Dear All,
    I have added routing point such as 811800 in CME when I used Hyperion to query data it shows that routing point in routing point template.
      My question is when I delete RP 811800 in CME why in Hyperion still have that RP and How long will be disappear.
      If I deleted RP 811800 and add it again so in Hyperion it will show 2 RPs (811800 and 811800)? and how can I know which one is a new one?
Best regard,
Lekie
Offline catanirex
Re: datamart
« Reply #1 on: August 26, 2009, 10:23:29 AM »
If you only want Hyperion to show the current object, you need to add this in the reports. Only display object with delete_time NULL.
But since it is Historical reporting, the RP have been existing!
If you select both RPs, I think that Hyperion will join the stat and present it as one RP.
Thats how out Hyperion reports works
sweetsbulu
Re: datamart
« Reply #2 on: August 26, 2009, 11:31:08 AM »
I am agree with the above comments suggested.
Because Hyperion is for Historical reporting if your deleted from CME but not from Datamart i think so.
Check OBJECT table and Obj_To_Obj table for more details according to the presentation name or object id.
Let me know any issues.
sweetsbulu
sweetsbulu@gmail.com
Re: datamart
« Reply #3 on: August 26, 2009, 11:33:36 AM »
Please check the Object table where you will get the child id and parent id.
According to that check if there is 2 objects are there means the prevoius object is not deleted.
sweetsbulu
Offline lekie
Re: datamart
« Reply #4 on: August 27, 2009, 04:03:05 AM »
Thanks you all guy
