" /> Redundancy for GVP - Genesys CTI User Forum
Author Topic: Redundancy for GVP  (Read 1661 times)
Offline Gremlin
Redundancy for GVP
« on: September 06, 2009, 04:49:19 PM »
Like to compare GVP with Avaya's AVP.
In AVP, if any single MPP (GVP IPCS equalivent) fails, their VPMS (GVP EMPS equalivent) is able to re-license and re-distribute the ports to other MPPs. Is GVP EMPS able to do the same without GVP HA lic ?
[b][u]Thus, in an example.[/u][/b]
Total lic 200 ports ( Primary lic file stored in central server at Site A, while backup lic file stored in site B) – no HA lic required.
Site A: IPCS_A with 100 ports
Site B: IPCS_B with 100 ports
If site A is down, will IPCS_B will be able to now accept 200 port calls ?
ie. Will EMPS be able to re-license and re-distribute the ports to other IPCS at other sites?
thanks!
Gremlin
Offline Lily
Re: Redundancy for GVP
« Reply #1 on: September 09, 2009, 01:54:27 PM »
I'm not sure but if it does work, you cannot forget to configure in the EMPS > PopGateway > Route for 200 ports in each IPCS; also if you're using the URS to distribute the calls, you'd need two Place Groups,
PlaceGroup1 = 100 first ports from IPCS_A and 100 first ports from IPCS_B
PlaceGroup2 = 100 last ports from IPCS_A and 100 last ports from IPCS_B
in the Strategy you'd do something like this:
[b]Entrance [/b]> [b]Target1 (PlaceGroup1) [/b] > [b]exit ok[/b]
                        v [exit not ok]
                [b]Target2 (PlaceGoup2)[/b]
also, you'd have to disable the all places in the CME, from the not working IPCS.
