" /> Agent not login - Genesys CTI User Forum
Author Topic: Agent not login  (Read 2799 times)
Offline jingoi
Agent not login
« on: September 09, 2009, 08:06:42 AM »
When i try to agent login error display "Selected user is disabled or please Check your Host and port settings for Genesys"
The user is already enable in CME also extension is defined
Re: Agent not login
« Reply #1 on: September 09, 2009, 08:43:20 AM »
Hi, Bob,
let's try with obvious:
are you using GAD or not?
Can you please:
1. post the part of T-Server log that gets RequestLoginAgent command and any events to it
2. Config Server log showing interaction between your Softphone and ConfigServer (if any)
Probably, it is something very silly and you have just overlooked it.
Best regards,
Offline jingoi
Re: Agent not login
« Reply #2 on: September 10, 2009, 02:10:34 AM »
NO we dont use GAD .
in TSERVER logs no agent login request comming from ADT.or any event
I have check TSERVER service is also running
Re: Agent not login
« Reply #3 on: September 10, 2009, 02:48:55 AM »
As Vic said, logs please. I can't imagine on how do you pretend us to help you if we can only guess.
Offline bogdan
Re: Agent not login
« Reply #4 on: September 10, 2009, 09:15:56 PM »
plug it :))))
sorry...my bad
try ping/telnet from client machine to server... may be helpfull in your case
Regards
