" /> GAD Issue - Genesys CTI User Forum
Author Topic: GAD Issue  (Read 6554 times)
shriramK
GAD Issue
« on: September 10, 2009, 12:26:32 PM »
I am not able to login to GAD , It says "cannot login to medai chat". When i checked the interaction server logs it has the below error
07:23:51.529 Trc 26015 Received message 'RequestSubscribe' ('183') from client 'AASDesktop_Pri' - Proxy:4:748, message attributes:
attr_ref_id [int] = 7
attr_ps_topic_list [list, size (unpacked)=94] =
  '101@gcs_cacon_3412pl' [str] = "1"
attr_prxy_client_id [int] = 5
attr_extension [list, size (unpacked)=44] =
07:23:51.529 Trc 26019 Sending message 'EventAck' ('125') to client 'gcs_cacon_3412pl' - Agent application:5:748 through proxy 'AASDesktop_Pri' - Proxy:4:748, message attributes:
07:23:51.560 Trc 26015 Received message 'RequestAddMedia' ('143') from client 'AASDesktop_Pri' - Proxy:4:748, message attributes:
attr_ref_id [int] = 8
attr_media_type_name [str] = "chat"
07:23:51.560 Trc 23009 Unsupported media type 'chat' for tenant 'Resources' (id '101') specified in request 'RequestAddMedia' from client 5:748, reference id: 8
07:23:51.560 Trc 26019 Sending message 'EventError' ('126') to client 'gcs_cacon_3412pl' - Agent application:5:748 through proxy 'AASDesktop_Pri' - Proxy:4:748, message attributes:
attr_error_code [int] = 18
attr_error_desc [str] = "Unsupported media type"
Kindly help me in resolving the issue.
tony
Re: GAD Issue
« Reply #1 on: September 10, 2009, 01:20:30 PM »
  • Hi,
    To start at the beginning;
    Are you usually able to use the Chat function in GAD..?
    T
    shriramK
    Re: GAD Issue
    « Reply #2 on: September 10, 2009, 02:43:56 PM »
  • Yes Tony ....
    tony
    Re: GAD Issue
    « Reply #3 on: September 10, 2009, 03:07:56 PM »
  • Sorry - had to ask... :)
    Try a v quick check of your Interaction Server (TServer);
    Options>reporting-extensions>interactions = "enable:all"
    Tony
    shriramK
    Re: GAD Issue
    « Reply #4 on: September 10, 2009, 03:08:21 PM »
  • Anyone pls temme a solution ..its a bit urgent....
    shriramK
    Re: GAD Issue
    « Reply #5 on: September 10, 2009, 03:09:35 PM »
  • Tony,
          I checked . It is given as enable all only.....
    tony
    Re: GAD Issue
    « Reply #6 on: September 10, 2009, 03:12:18 PM »
  • If it is v urgent, please raise a Priority SR with Genesys - this board is full of part-time volunteers...
    T
    Offline YevgeniyP
    Re: GAD Issue
    « Reply #7 on: September 11, 2009, 03:09:19 AM »
  • based on message "Unsupported media type 'chat' for tenant 'Resources' (id '101')" I assume that media type chat is not configured in "Resources" tenant (case matter).
    Additional question: Why do you use Resources tenant, any particular reason?
