" /> Adding Groups to CCPulse - Genesys CTI User Forum
Author Topic: Adding Groups to CCPulse  (Read 3725 times)
Offline PFCCWA
« on: September 18, 2009, 08:06:40 PM »
Is it possible to add groups to a CCPulse (v7.5) view after they have been selected?
At the moment, if for example we create a view (with multiple tabs/templates) then add a DN Group in CME, the whole thing has to be recreated to accommodate the addition - as we didnt select it in the first place because it had not existed before.
Also if the tabs are created in a order, can they be rearranged after?  Its not obvious if they can so we are deleting and recreating in the desired order for the time being.
WA
Re: Adding Groups to CCPulse
« Reply #1 on: September 18, 2009, 11:35:54 PM »
Hit new and it will keep the current config. Also in CCPulse application be sure that the notify new objects property is enabled.
Offline mark
« Reply #2 on: September 21, 2009, 06:26:34 PM »
little note: When clicking new in ccpulse, you might need to select the child box for parent properties for any current objects.
Offline Scottyjohn
« Reply #3 on: September 23, 2009, 12:27:23 PM »
I know its a real pain, even if the objects remain selected, its a nightmare having to apply templates and thresholds etc all over again.  To make it worse, if you have a lot of templates, and you have renamed each view so that the tab shows a meaningful name, you cant actually see which template was used to create the view.  We got round this by putting the template name in the stat section header, that way you can always see which template is being used for each view.
Miguel
« Reply #4 on: September 23, 2009, 02:00:56 PM »
Where can I see that the notify new objects property is enabled.
