" /> VCS Upgradation - Genesys CTI User Forum
Author Topic: VCS Upgradation  (Read 4572 times)
Sunil Kumar
VCS Upgradation
« on: October 20, 2009, 08:04:07 PM »
I have to upgrade the VCS from  7.6.400.08 to 7.6.440.05 version. Can anyone please tell me the steps that i have to follow while doing the upgradation? Do I need to uninsatall the existing version and do a fresh installation or can I do the installation of new version directly on the existing installation?
Can anyone please help in this?
Thanks in advance.
Re: VCS Upgradation
« Reply #1 on: October 20, 2009, 11:06:11 PM »
  • Just uninstall old version and install new version, all configuration will be stored by EMPS.
    Offline Reinoud de Lange
    Re: VCS Upgradation
    « Reply #2 on: October 21, 2009, 02:58:59 PM »
  • Will this also work from 7.5 to 7.6? I noticed some differences in the EMPS...
    Re: VCS Upgradation
    « Reply #3 on: October 21, 2009, 03:16:08 PM »
  • Never tried to combine versions of components...can't tell...
    Sunil Kumar
    Re: VCS Upgradation
    « Reply #4 on: October 21, 2009, 03:25:28 PM »
  • Just to confirm, Are the following steps correct in installing the GVP?
    1. Uninstall the Popgateway (uninstalling the VCS means uninstalling the Popgateway?)
    2. Install the new version of VCS.
    Is this the right way? Can you please confirm?
    Offline sunbabu15
    Re: VCS Upgradation
    « Reply #5 on: October 28, 2010, 08:50:02 AM »
  • Hi Guys,
    I am into a similar situation.Please do reply with u r suggestion.
    Regards,
