" /> Starting CME using command line (similar to CCPulse) - Genesys CTI User Forum
Author Topic: Starting CME using command line (similar to CCPulse)  (Read 3867 times)
Offline Scottyjohn
« on: October 28, 2009, 04:09:59 PM »
Hi all,
As per the subject line, is there a way to achieve this so that I can log into different environments by clicking a batch file?
Lazy I know .....  ;D
tony
Re: Starting CME using command line (similar to CCPulse)
« Reply #1 on: October 29, 2009, 10:02:03 AM »
Yep - something like this:
"SET SCE_ACCESS=COMMAND_LINE (not entirely sure this will work but it does for CCPulse - check syntax! :) )
SET HOSTNAME=hostname
SET PORT=0000
SET APPLICATIONNAME=appname
SET USERNAME=username
SET PASSWORD=password
C:\Program Files\...path_to...\sce.exe -host %HOSTNAME% -port %PORT% -user %USERNAME% -pwd %PASSWORD% -app %APPLICATIONNAME%"
Tony
