" /> Extension get call delay - Genesys CTI User Forum
Author Topic: Extension get call delay  (Read 2998 times)
Offline lekie
« on: November 10, 2009, 03:19:38 AM »
Hi All,
      Here is an extension get recieved call delay, whoever is logged-in in this extension would recieved the inbound call delay but other extension it's working well.
Have anyone face the problem like this? or how can i check in the log file?
Thanks you in advance,
Lekie
Re: Extension get call delay
« Reply #1 on: November 10, 2009, 03:22:55 AM »
Can you explain better? What is a call delayed?
Offline lekie
« Reply #2 on: November 10, 2009, 07:50:47 AM »
  For example,There are extension 7001 -7005 and Agent 1 - Agent 5.
So Agent 1 has highest skill level is 5 and Agnet 4 - 1 decrease in the row.
Agent 1 was logging in extension 7001 that the extension has the problem.
There are call waiting in queue,Agent 1 and Agent 2 are available and have idel time as the same but the inbound call go to Agent 2 first. I try to change another Agent  who is higher skill level log-in on ext 7001 but still got the same problem. Have you face the problem like that?
Thanks you inadvance.
Cheers,
Lekie
« Reply #3 on: November 10, 2009, 04:16:21 PM »
Leekie,
Skill level doesn't represent any priority or preference unless you use ServiceLevel routing object in routing strategy. Is that your case?
Offline lekie
« Reply #4 on: April 05, 2010, 08:29:09 AM »
T am not use ServiceLevel to route the customer call.
Offline ecki
« Reply #5 on: April 08, 2010, 03:30:17 AM »
You would have to post the URS logfile covering the test case period.
e.
