" /> Outbound rescheduling - Genesys CTI User Forum
Author Topic: Outbound rescheduling  (Read 2915 times)
Offline sreeschand
« on: December 16, 2009, 07:49:01 PM »
I need help on outbound rescheduling.
Here is the scenario
* Making an outbound call using OCS and CPD.
* We get live customer
* Call then transfers to an agent
* Agent reschedules the call and updates the record.
Problem with above scenario is if agent reschedules the call less then 1 hour it works fine.
but when reschedules the call more than 1 hour then record is not updating and in log we are getting
GSW_ERROR 'Invalid Time'
Any help on this greatly appreciated.
Sree
Re: Outbound rescheduling
« Reply #1 on: December 16, 2009, 09:29:02 PM »
Can you post the logs?
JF
« Reply #2 on: January 26, 2010, 08:44:37 PM »
Which version of OCS you are using ?
I saw a quit similar scenario, if you are just near your Daily_till it goes automatically on the next day.
JF
