" /> Does Genesys tlib 7.6 support windows 2008 32 bit - Genesys CTI User Forum
Author Topic: Does Genesys tlib 7.6 support windows 2008 32 bit  (Read 2837 times)
Offline Johnfj
« on: January 25, 2010, 04:53:21 PM »
I'm trying to find out if genesys tlib v7.6 supports windows 2008 32bit ? Any info or links will be helpful, thank you JJ
« Last Edit: January 25, 2010, 04:59:05 PM by Johnfj »
Offline Gert
Re: Does Genesys tlib 7.6 support windows 2008 32 bit
« Reply #1 on: January 26, 2010, 10:31:57 AM »
Out of the Genesys Supported Operating Systems and Databases Reference Manual the answer is No, it only supports MS Windows
Server 200 32-bit.
