" /> SIP Trunk DN Capacity option question.... - Genesys CTI User Forum
Author Topic: SIP Trunk DN Capacity option question....  (Read 4502 times)
Offline Scottyjohn
« on: February 11, 2010, 04:06:40 PM »
Hi all,
I am looking at the ability to set the capacity rule on DNs of type "trunk" used for inter sip server communications.  Can anyone tell me what happens to the sip traffic when the capacity rule is reached?  I dont know if the traffic is rejected or what?  I also looked to see if I could get any kind of alarm to trigger based on a log event for this breach of capacity but couldnt finmd any mention of a log event for this scenario, anyone know if there is one?
Re: SIP Trunk DN Capacity option question....
« Reply #1 on: February 11, 2010, 05:20:55 PM »
What do you mean by a "capacity rule"? You want to limit the ammount of calls?
Offline Timur Karimov
« Reply #2 on: February 12, 2010, 09:45:36 AM »
Hi there
The latest SIP T-Serevr version is support capacity and capacity-group option on trun DN-type. The result of the over-capacity call is the same as the your default system wrong routing behaviour.
WBR
Offline Scottyjohn
« Reply #3 on: February 12, 2010, 11:12:33 AM »
Hi all,
So the call that is deemed as over the assigned capacity on a trunk DN between SIPserver A and SIPserver B, will be defaulted based on the routing rules defined on the originating SIPServer?
« Reply #4 on: February 13, 2010, 08:58:02 AM »
[quote author=Scottyjohn link=topic=5154.msg22823#msg22823 date=1265973153]
Hi all,
exactly. but also don't forget about active participation the URS in the routing process.
