" /> Backup TServer in GPlus 7.5 Configuration - Genesys CTI User Forum
Author Topic: Backup TServer in GPlus 7.5 Configuration  (Read 3227 times)
Jofre
« on: February 17, 2010, 07:49:34 AM »
If we have T-Server and T-Server HA in Hot Standby, how we must configure it in Siebel 8 for the GPlus Adapter 7.5?
Driver:TServerAppName refers to primary T-Server, but it seems there's no other configuration for backup T-Server. Is it correct? In pre-7.5, you can configure Driver:BackupServerHost and Driver:BackupServerPort for backup T-Server
Is there any way to configure it in 7.5? Is it enough with the TserverAppName Option or is it imperative to configure the backup T-Server? And how?
Thank you.
Re: Backup TServer in GPlus 7.5 Configuration
« Reply #1 on: February 17, 2010, 03:41:23 PM »
  • Hi Jofre,
    Gplus Communication Server will handle HA for TServer itself. It is necessary to add primary TServer to connection of Gplus CommServer application and configure correct TServer name in Gplus Driver options (Driver:TServerAppName) only.
    You can still use pre-7.5 configuration but I don't see any benefit of it. I did several deployments of Gplus adapter using new way and it works correctly.
