" /> Loss of synchronisation causes - Genesys CTI User Forum
Author Topic: Loss of synchronisation causes  (Read 3043 times)
Offline Sophie
« on: March 08, 2010, 08:20:11 AM »
I think I'm facing an issue about synchronizing time between my Genesys machines.
Indeed a few problems occured with several applications such as Genesys Agent Desktop 7.6 or CCPulse 7.5
According to the log files and what I've been told, it seems that these applications lose their synchronisation with the TServer 7.6
Does anyone know if there is another reason that may explain this loss except from synchronizing time between machines?
Offline Lorenzo
Re: Loss of synchronisation causes
« Reply #1 on: March 08, 2010, 04:54:49 PM »
Do you have log regarding this issue ?
What error message do you get ?
Offline Sophie
« Reply #2 on: March 08, 2010, 09:13:40 PM »
:-\ Sorry I didn't keep the log files and they have been deleted.
As far as my last problem with GAD is concerned I got the following error messages:
[b]272[/b] [i]Warning logged on elsewhere[/i] -> but it wasn't true, the agent wasn't logged anywhere
[b]128[/b] [i]Bad DN type for DN registration[/i] -> for the Agent logins that were configured as ACD Position with Switch specific Type =1
[b]41[/b] [i]DN is not registered[/i] -> but it worked well before
And in the GAD we could have seen: "[i]DN [Agent Login] is out of service[/i]"
When I restarted the GAD StatServer and GAD, it worked well again.
Offline Fra
« Reply #3 on: March 08, 2010, 11:08:44 PM »
[quote author=Sophie link=topic=5378.msg23449#msg23449 date=1268082820]
sorry, we can't help much without them  :)
you think he was not, but somehow he was still for GAD, probably he didn't log out properly.
we can't say whether that it correct or not, it depends on the switch you are using.
we can't help without logs, but the error is self-explicating, it was not registered. If could work before, but well, this is another story :P
again, we can't help without logs, but the DN the agent was trying to log into was out of service.
Fra
Offline rpenney
« Reply #4 on: March 09, 2010, 12:07:21 AM »
Hi Sophie,
    All your problems can be explained IMHO by the loss of connectivity to T-Server as you said in your first post. As to why this happened, you cant really diagnose without the log files although my gut feel is network issues. If the other apps miss T-Server messages, then the problems you are experiencing can happen.
Time syncronisation between boxes shouldn't cause problems except when trying to match up log files.
Is GAD, GAD StatServer and the T-Server on the same box? If not, is ADDP set between the apps?
Are the boxes experiencing load issues?
If this was a once off issue, check with the LAN/WAN people to see if there were any problems/maintenance with the network before or at the time it happened.
If it keeps happening, get the logs and look for disconnections.
Good luck
Russell
Offline Sophie
« Reply #5 on: April 07, 2010, 09:53:57 AM »
Hello!
Thanks for your advice.
It was a network issue.
It came from the fact that security rules were compiled at this time. These rules are implemented on a firewall between the different VLANs where our environment is installed.
And during the procedure, the connection between our hosts is lost which entails that GAD is out of service for a while.
