" /> Prefix access - Genesys CTI User Forum
Author Topic: Prefix access  (Read 2196 times)
Offline dbleela
Prefix access
« on: April 29, 2010, 09:28:22 AM »
  We are using Genesys 7.5 version, using Audio code for PRI, we had created many campaigns and configured the access code for the same in the Audiocode and given the access in the dialer.
My problem is some of the callers are misusing the prefix access in one campaign to another campain. for example
X campaign access code is 7
Y campaign access code is 9
X campaign callers are misusing the Y campaign access code. if any option for restrict the misusing the access code.
pls reply
Offline Fra
Re: Prefix access
« Reply #1 on: April 30, 2010, 10:01:25 PM »
It depends where the access code is configured.
Fra
Offline dbleela
Re: Prefix access
« Reply #2 on: May 03, 2010, 09:24:32 AM »
PRI connected in Audiocode device and prefix also configured in Audiocode, same has been configured in Configuration Manager.
Offline dbleela
Re: Prefix access
« Reply #3 on: May 13, 2010, 09:13:48 AM »
Hi all,
  any one can give the solution for this.
Re: Prefix access
« Reply #4 on: May 13, 2010, 04:36:14 PM »
Hi dbleela,
It's quite hard to help as you haven't posted any information like log, configuration dump etc. we could analyse. The only recommendation I can give is to check log of OCS and TServer to ensure that correct prefix is used before the call is passed to Audicode. If it isn't then you should review you configuration and analyse OCS/T-Server logs in detail. If it is then you should focus on Audiocode.
