" /> [SOLVED] CME- Freeze - Genesys CTI User Forum
Author Topic: [SOLVED] CME- Freeze  (Read 3028 times)
phil
« on: April 30, 2010, 10:12:34 AM »
Hi there,
on certain conditions CME (latest version 7.6.001.03) freezes and is no longer useable till restart.
had the finder open and a few other objects. when highlighting several objects in a childfolder of CME- Browser with mouse dragging the error above occurs. no error msg  is prompted.
is that a known issue to some of you?
« Last Edit: April 30, 2010, 11:48:56 AM by phil »
phil
Re: CME- Freeze
« Reply #1 on: April 30, 2010, 10:29:45 AM »
I could also reproduce it after a downgrade to 7.6.001.01.
phil
Re: [SOLVED] CME- Freeze
« Reply #2 on: April 30, 2010, 11:51:45 AM »
This happens if you highlight object 2-3 times serially, even if just the CME main window is used. Right-click on the CME tab in the task bar fixes it.
Nevertheless, no proper behaviour.
Marked as best answer by on October 30, 2025, 06:29:16 AM
« Reply #3 on: April 30, 2010, 06:09:05 PM »
  • Undo Best Answer
  • Have you tried on different computers? Seems more to me like a process issue...
