" /> UCS DAP - JDBC Integration - Genesys CTI User Forum
Author Topic: UCS DAP - JDBC Integration  (Read 3048 times)
Offline RDB
« on: May 06, 2010, 08:50:13 AM »
Hi All,
I am trying my hands on the UCS DAP Integration with JDBC for the first time but with no success.
I am not a Java expert either. Hence was facing difficulty in setting up the UCS DAP and JDBC integration. Not able to find much in any documents as well.
If anyone of u have already tried that pls feel free to advise me on this procedure.
Re: UCS DAP - JDBC Integration
« Reply #1 on: May 06, 2010, 05:07:42 PM »
You can find detailed description in Multimedia 7.6 Deployment's Guide on page 109.
Offline RDB
« Reply #2 on: May 07, 2010, 03:33:20 PM »
Hi Rene,
I was talking abt configuring the JDBC part in the system.
I am not able to configure the required settings for JDBC in the system.
Can u pls help me as to how the JDBC installation is to be done in the system, any jar files to be
played with or any system settings to be modified.
Any help wud be highly appreciated.
Regards.
Offline RDB
« Reply #3 on: May 07, 2010, 03:34:27 PM »
And the most important as to where to give the JDBC port no. for the database.
Offline catanirex
« Reply #4 on: May 10, 2010, 06:27:49 AM »
The jar file is proviced by Genesys in the UCS installation package.
In order to configure a JDBC-DAP: Right clic on the DAP, select Wizard/Configure.
The port for MS-SQL are usually 1433 and Oracle 1521 - but check with your DBA!
GOdd luck!
