" /> GAD - Agent history - Genesys CTI User Forum
Author Topic: GAD - Agent history  (Read 3741 times)
Offline New...
GAD - Agent history
« on: May 11, 2010, 05:06:03 PM »
In GAD, is it possible for the agents to view the history of email interactions that they have handled (like, Inbox and Sent items)?
Re: GAD - Agent history
« Reply #1 on: May 11, 2010, 05:21:19 PM »
Yes, just search for a contact and you will see the history of that contact.
Offline New...
« Reply #2 on: May 11, 2010, 07:06:12 PM »
We need to find based on agent and not based on contact.... The agents want to know the details of the email interactions that they have handled.....
Offline Timur Karimov
« Reply #3 on: May 12, 2010, 05:52:12 AM »
[quote author=New... link=topic=5531.msg24203#msg24203 date=1273604772]
you can achive this by adding custom atributes with search capabilities . you can found the detail describe for this in GAD Deployment Guide.
WBR
« Reply #4 on: May 12, 2010, 09:29:15 AM »
Just a note - Search feature is supported starting release 8.0 of UCS.
Offline Boy
« Reply #5 on: May 26, 2010, 09:51:50 AM »
Timur,
What did you mean  ‘add custom attributes’. I know it is possible to add attributes to Contact (not an interaction) and later it is possible search by this attribute in ‘Contacts’ tab. Did you mean anything else?
boy
« Reply #6 on: June 01, 2010, 06:09:32 AM »
[quote author=Boy link=topic=5531.msg24373#msg24373 date=1274867510]
Timur,
boy
Hi there!
Yes, i mean exactly it function. you can use attribute like the standard "last routed agent" for create frow send strategy key pair with "agent who reply" data. then , if you need  - seek by this attribute and you found all contact and their message. it's not exactly what you want-  but it does not requered any hard customization of GAD.
WBR.
