" /> cannot transfe data from ODS to Datamart - Genesys CTI User Forum
Author Topic: cannot transfe data from ODS to Datamart  (Read 2025 times)
Offline lekie
« on: May 24, 2010, 09:24:12 AM »
Hi All,
I have found some error as below in the datasourcer log file
What should I fix this problem? I use to add a new Layout in DMA but now I already delete it I think when I added a new layout that is the root cause of the problem.
2010-05-24 12:10:10.134 Reading all objects from ODS...
2010-05-24 12:10:10.181 DBWriter: Added Chunk Schedule(20,6) Time [1274672100,1274672400] <2010-05-24 10:40:00 300>
2010-05-24 12:10:10.181 DBWriter: Found chunk file chunk1274672400_20.csv
2010-05-24 12:10:10.212 DBWriter: Added Chunk Schedule(22,6) Time [1274672100,1274672400] <2010-05-24 10:40:00 300>
2010-05-24 12:10:10.212 DBWriter: Found chunk file chunk1274672400_22.csv
2010-05-24 12:10:10.290 DBWriter: Added Chunk Schedule(25,0) Time [1274672100,1274672400] <2010-05-24 10:40:00 300>
2010-05-24 12:10:10.290 DBWriter: Found chunk file chunk1274672400_25.csv
2010-05-24 12:10:10.321 DBWriter: Added Chunk Schedule(26,0) Time [1274672100,1274672400] <2010-05-24 10:40:00 300>
2010-05-24 12:10:10.321 DBWriter: Found chunk file chunk1274672400_26.csv
2010-05-24 12:10:10.337 631 active objects found in ODS.
2010-05-24 12:10:10.352 OLAgent diff: '' not equals to the ' '
2010-05-24 12:10:10.368 OLAgent diff: '' not equals to the ' '
Best regards,
Lek
Offline Dhanasekar
Re: cannot transfe data from ODS to Datamart
« Reply #1 on: June 14, 2010, 09:53:27 AM »
If your using Sqlserver check the DB_Properties in ODS and Datamart DB will have the code it should be same in ODS and DMart then ur data will be transfered
