" /> Best tool for analyzing the Log files - Genesys CTI User Forum
Author Topic: Best tool for analyzing the Log files  (Read 3054 times)
Offline Bashu
« on: May 31, 2010, 11:06:15 AM »
Someone suggest me the best tool for analyzing log file other than Kazmir.
If you have please provide me.
Basheer.
Offline Steve
Re: Best tool for analyzing the Log files
« Reply #1 on: May 31, 2010, 06:58:48 PM »
Grep and Windows Grep are good for finding particulat strings in logs.
TextPad with tserver-log.syn is good for reading through them.
A quick Google just turned up Genaalyze, something to try.
On the subject of Kasimir, it is worth noting that there are 2 different log tools with this name. One written by a guy called Sergey from Genesys (available from Genesys and sometimes on the web) and a different one available via Sourceforge written in PERL.
Offline ecki
« Reply #2 on: May 31, 2010, 09:23:48 PM »
There is another Genesys tool "ts2db" which converts events in to excel, csv or sql (oracle or mssql).
Offline Bashu
« Reply #3 on: June 01, 2010, 07:13:19 AM »
Thanks a ton Steve
At present i have been using Text pad and kasimir. I have downloaded genalyze also but i dnt know how to use genalyze tool i have tried a lot  :-[.
Basheer.
