" /> GIS fails on Initialization - Genesys CTI User Forum
Author Topic: GIS fails on Initialization  (Read 3754 times)
phil
« on: June 10, 2010, 12:12:11 PM »
Hi there,
What else to say...? Here 's the log:
Application name: GenesysIntegrationServer
Application type: CFGIntegrationServer(112)
Host name:        test0
Time zone:        Zentraleuropäische Zeit
Local time:      2010-06-10T13:45:55.739
UTC time:        2010-06-10T11:45:55.739
Start time (UTC): 2010-06-10T11:45:55.708
Running time:    0:00:00:00.031
Memory usage:    143.589.376
Host info:        Windows 2003, 5.2, x86, 1.5.0_16-b02, Java HotSpot(TM) Server VM, mixed mode
File:            (1) D:\var\log\genesys\GenesysIntegrationServer\GenesysIntegrationServer.20100610_134555_725.log
13:45:55.739 Trc 04112 The Log Output of type 'D:\var\log\genesys\GenesysIntegrationServer\GenesysIntegrationServer' has been created and opened
13:45:55.739 Trc 04500 Connecting to Message server 'MessageServer' at host 'test0.domain.de', port 2040
13:45:55.739 Trc 04112 The Log Output of type 'network' has been created and opened
13:45:55.755 Trc 04110 Option 'verbose' has been set to the value 'all'
13:45:55.755 Trc 04110 Option 'buffering' has been set to the value 'false'
13:45:55.755 Trc 04110 Option 'expire' has been set to the value '10'
13:45:55.755 Trc 04110 Option 'segment' has been set to the value '10000'
13:45:55.755 Trc 04110 Option 'spool' has been set to the value ''
13:45:55.755 Trc 04110 Option 'message-file' has been set to the value 'C:\GCTI\GenesysIntegrationServer2\bin\webapps\gis\conf\gis.lms'
13:45:55.755 Trc 04110 Option 'time-format' has been set to the value 'time'
13:45:55.755 Trc 04110 Option 'time-convert' has been set to the value 'local'
13:45:55.755 Trc 04110 Option 'message-format' has been set to the value 'short'
13:45:55.755 Trc 04110 Option 'memory-storage-size' has been set to the value '512 Kb'
13:45:55.755 Trc 04110 Option 'check-point' has been set to the value '1'
13:45:55.708 Trc 04110 Option 'message-file' has been set to the value 'C:\GCTI\GenesysIntegrationServer2\bin\webapps\gis\conf\gis.lms'
13:45:55.708 Trc 04106 Log Messages file 'C:\GCTI\GenesysIntegrationServer2\bin\webapps\gis\conf\gis.lms' successfully loaded
13:45:55.708 Trc 04110 Option 'verbose' has been set to the value 'all'
13:45:55.708 Trc 04110 Option 'buffering' has been set to the value 'false'
13:45:55.724 Trc 04110 Option 'expire' has been set to the value '10'
13:45:55.724 Trc 04110 Option 'segment' has been set to the value '10000'
13:45:55.724 Trc 04110 Option 'spool' has been set to the value ''
13:45:55.724 Trc 04110 Option 'message-file' has been set to the value 'C:\GCTI\GenesysIntegrationServer2\bin\webapps\gis\conf\gis.lms'
13:45:55.724 Trc 04110 Option 'time-format' has been set to the value 'time'
13:45:55.724 Trc 04110 Option 'time-convert' has been set to the value 'local'
13:45:55.724 Trc 04110 Option 'message-format' has been set to the value 'short'
13:45:55.724 Trc 04110 Option 'memory-storage-size' has been set to the value '512 Kb'
13:45:55.724 Trc 04110 Option 'check-point' has been set to the value '1'
13:45:55.724 Trc 04113 The Log Output of type 'stderr' has been closed and deleted
13:45:55.771 Trc 04110 Option 'message-file' has been set to the value 'C:\GCTI\GenesysIntegrationServer2\bin\webapps\gis\conf\gis.lms'
13:45:55.771 Std 20011 ----- logger created -----
13:45:55.771 Std 04503 Connected to MessageServer 'MessageServer' at host 'test0.domain.de', port 2040
13:45:55.943 Trc 20009 HA: primary= null , backup= null
Connected to LCA, port 4999
13:45:55.958 Trc 20009 module : lca initialized
13:45:55.958 Trc 20009 Adding module notification
13:45:55.989 Trc 20009 module : notification initialized
13:45:56.052 Std 07101 Feature 'GIS': 1 licenses checked out
13:45:56.083 Trc 20009 SessionService added
13:45:56.114 Trc 20009 StatService added
13:45:56.114 Trc 20009 CSProxyService added
13:45:56.114 Trc 20009 Start to initialize (3) services :
13:45:56.114 Trc 06084 Configuration option set: 'SessionService':'sessionTimeout' = '3600'
13:45:56.114 Trc 06084 Configuration option set: 'StatService':'restriction_time' = '3'
13:45:56.114 Trc 06084 Configuration option set: 'StatService':'error_check' = 'true'
13:45:56.114 Trc 06084 Configuration option set: 'StatService':'scopeStatEvents' = '15'
13:45:56.271 Std 04503 Connected to Stat Server 'StatServer_AIL_GIS' at host 'test2.domain.de', port 2070
13:45:56.271 Dbg 20012 SOpenServerEx: StatServer_AIL_GIS@test2.domain.de:2070
13:45:56.286 Std 04503 Connected to SOAP Server 'confserv' at host 'test0.domain.de', port 2022
13:45:56.302 Trc 20009 Service SessionService is running
13:45:56.302 Trc 20009 Service StatService is running
13:45:56.302 Trc 20009 Service CSProxyService is running
13:45:56.302 Trc 20009 GIS server 7.6.101.02 started
13:45:56.302 Std 05060 Application started
13:45:56.302 Trc 20009 GIS server launched by :InitGIS
13:45:57.333 Trc 20009 [main] com.genesyslab.soa.impl.SOAFactory SOA Services version : 7.6.100.11 initializing
13:45:57.349 Dbg 20012 [main] com.genesyslab.soa.impl.mbeans.MBeanAgent Create configuration registry ...
13:45:57.396 Dbg 20012 [main] com.genesyslab.soa.impl.mbeans.MBeanAgent Creating MBeanServer ...
13:45:57.396 Dbg 20012 [main] com.genesyslab.soa.impl.mbeans.MBeanAgent Creating adapters ...
13:45:57.443 Trc 20009 [main] com.genesyslab.soa.impl.SOAContainer SOA Services version : 7.6.100.11 initialized
13:45:57.693 Dbg 20012 [main] com.genesyslab.openmedia.soa.impl.mbeans.MBeanAgent Create configuration registry ...
13:45:57.708 Dbg 20012 [main] com.genesyslab.openmedia.soa.impl.mbeans.MBeanAgent Creating MBeanServer ...
13:45:58.396 Trc 20009 [main] com.genesyslab.soa.impl.SOAContainer OPENMEDIA Services version : 7.6.100.11 initialized
13:45:58.661 Dbg 20012 [main] com.genesyslab.ail.ws.impl.mbeans.MBeanAgent Create configuration registry ...
13:45:58.693 Dbg 20012 [main] com.genesyslab.ail.ws.impl.mbeans.MBeanAgent Creating MBeanServer ...
13:46:01.192 Trc 20009 [main] com.genesyslab.soa.impl.SOAContainer AIL Services version : 7.6.100.11 initialized
13:46:01.192 Std 05094 Application is not able to provide service
13:46:01.192 Trc 20009 AIL added
13:46:01.208 Std 05094 Application is not able to provide service
13:46:01.208 Trc 20009 OPENMEDIA added
13:46:01.208 Trc 20009 [main] HA.ProxyDB HaProxyDB.getDataToRecover: timeout expired, no saving during 41294399 sec
13:46:01.224 Trc 20009 [main] HA.services QILService recover of om : nb= 0
13:46:01.224 Trc 20009 [main] HA.services HA recover of ail/login : count= 0, failed= 0, Times(ms): getDns= 0 getData= 0 recover= 0
13:46:01.224 Trc 20009 [main] com.genesyslab.ail.ws.interaction.impl.InteractionEventImpl HA recover of ail/mapixnids : count= 0
13:46:01.224 Trc 20009 [main] HA.services recover is finished
13:46:01.286 Dbg 20012 Stopping false
13:46:01.286 Trc 20009 destroy service SessionService
13:46:01.286 Trc 20009 Service SessionService Destroyed
13:46:01.286 Trc 20009 destroy service AIL
13:46:01.302 Trc 20009 [GIS SIG INT HANDLER] com.genesyslab.soa.impl.SOAContainer AIL Services version : 7.6.100.11 Stopped
13:46:01.302 Std 05094 Application is not able to provide service
13:46:01.317 Trc 20009 Service AIL Destroyed
13:46:01.317 Trc 20009 destroy service StatService
13:46:01.317 Std 20008 Disconnecting from StatServer StatServer_AIL_GIS
13:46:01.317 Trc 20009 Service StatService Destroyed
13:46:01.317 Trc 20009 destroy service OPENMEDIA
13:46:01.317 Trc 20009 [GIS SIG INT HANDLER] com.genesyslab.soa.impl.SOAContainer OPENMEDIA Services version : 7.6.100.11 Stopped
13:46:01.317 Std 05094 Application is not able to provide service
13:46:01.317 Trc 20009 Service OPENMEDIA Destroyed
13:46:01.317 Trc 20009 destroy service CSProxyService
13:46:01.317 Trc 20009 Service CSProxyService Destroyed
13:46:01.317 Std 05063 Normal termination
13:46:01.333 Trc 20009 LicenseControl::ReleaseAll
13:46:01.333 Trc 04109 Logging service stopped
13:46:01.333 File 'D:\var\log\genesys\GenesysIntegrationServer\GenesysIntegrationServer.20100610_134555_725.log' closed
Any help is appreciated
Cheers
:-Phil
phil
Re: GIS fails on Initialization
« Reply #1 on: June 11, 2010, 08:05:39 AM »
  • Fixed! Thanks tho.
    Offline jsloan2
    « Reply #2 on: October 18, 2010, 01:41:27 PM »
  • What was the fix please?
