" /> Adding a subject to the GAD login page - Genesys CTI User Forum
Author Topic: Adding a subject to the GAD login page  (Read 2458 times)
Offline Tambo
« on: June 26, 2010, 06:00:29 PM »
does anyone know if it's possible to add another subject box into the GAD login box??
so when agents go to put in their username and password there could be another box that would display a message of some sorts.
as far as I can see this login box is a jsp file but dont know enough to say yes or no to the business.
Re: Adding a subject to the GAD login page
« Reply #1 on: June 26, 2010, 06:13:58 PM »
You can modify the JSP file but probably will lose some warranty with that... no default way to do such implementation.
Offline Tambo
« Reply #2 on: June 26, 2010, 06:17:40 PM »
cheers Cav I expected as much but had to ask.
Tambo
