" /> ServiceFactor - Genesys CTI User Forum
Author Topic: ServiceFactor  (Read 3413 times)
Offline Tambo
ServiceFactor
« on: June 26, 2010, 06:15:16 PM »
I have used the pre built stat ServiceFactor and need to build a new one. I have created this ServiceFactor2 in the stats servers, DMA, CME etc basically I have mirrored everything that ServiceFactor has except the new time stat. I cannot get this to pull through so that I can use it within the template wizard in CCPulse.
Can anyone advise where I'm going wrong?????
cheers
Offline ecki
Re: ServiceFactor
« Reply #1 on: June 26, 2010, 10:11:04 PM »
Hi Tambo,
Are you using for CCPulse the same Stat Server as for CCA (DMA)?
E.
Offline Tambo
Re: ServiceFactor
« Reply #2 on: June 27, 2010, 04:06:55 PM »
Hi Ecki,
no we are using 2 different ones, a realtime one and one for data sourcer, but I have configured each with the same info as well as the backups ?!?!
Tambo
Offline ecki
Re: ServiceFactor
« Reply #3 on: June 28, 2010, 08:26:15 AM »
Check first logfile after start of your ss and try to find your statstics wether it is ignored or successfully registered.
Offline rpenney
Re: ServiceFactor
« Reply #4 on: June 28, 2010, 09:58:10 PM »
Try restarting the stat server.
Offline Tambo
Re: ServiceFactor
« Reply #5 on: June 30, 2010, 07:27:46 PM »
thanks chaps, yes restarting the ss worked. Its funny i've made others up before and not had to do a restart! i take it thats just genesys for you.
