" /> Email Routing - CCPulse report - Genesys CTI User Forum
Author Topic: Email Routing - CCPulse report  (Read 2977 times)
Offline New...
« on: July 01, 2010, 07:03:18 AM »
Hi All,
Is there a way to see how many number of emails were handled by an agent with respect to different interaction queues?
ie: Agent1 handled 10 emails from Interaction Queue1 and 5 emails from Interaction Queue2...
Is there a way to show these details in reporting?
tony
Re: Email Routing - CCPulse report
« Reply #1 on: July 01, 2010, 08:42:09 AM »
Hello! :)
It is not easy to mix/match reporting on 2 major Object Types on the same View in CCP.  You could try adding your Queue Names as attached data/KVP and use them on a Filter on the StatServer, then build an Agent View with the Queues as Filters.  But, I guess, that depends on how many Queues you need to report on...?
TT
Offline New...
« Reply #2 on: July 01, 2010, 09:19:54 AM »
Thanks, Tony. Implemented the same and it works fine.
tony
« Reply #3 on: July 01, 2010, 10:59:34 AM »
...that was quick...! lol
TT
