" /> Brio/Hyperion Hints and Tips.... - Genesys CTI User Forum
Author Topic: Brio/Hyperion Hints and Tips....  (Read 6180 times)
tony
« on: July 02, 2010, 06:45:42 AM »
Does anyone thinks it would be worth me putting up a Brio/Hyperion File (.bqy) of my own Hints and Tips?  I know I can't attach it here so it would have to go on my website - it has the following in it;
>>>Optimizing Connection Files (.oce)
>>>Using the Object and Object_to_Object Tables
>>>Optimizing Queries
>>>Using "Full Names"
>>>Using Local Results
...and some other bits and pieces....
TT
« Last Edit: January 20, 2011, 08:24:59 AM by victor »
Offline oklutep
Re: Brio/Hyperion Hints and Tips....
« Reply #1 on: July 02, 2010, 12:35:48 PM »
I definetely would be interested!
regards
o.
Offline bounty
« Reply #2 on: July 05, 2010, 02:08:53 PM »
Me too !
Offline oklutep
« Reply #3 on: July 06, 2010, 06:25:51 AM »
Thanks Tony. It worked for me.
o.
tony
« Reply #4 on: July 06, 2010, 09:08:13 AM »
Thanks - I downloaded a copy myself and, apart from starting on the wrong page, it loads up OK...
TT
Marked as best answer by on May 23, 2025, 07:17:59 PM
tony
« Reply #5 on: July 21, 2010, 08:04:52 AM »
  • Undo Best Answer
  • ...any feedback from anyone who downloaded this..?  Good, bad, too little, too much...?
    TT
    Offline karan
    « Reply #6 on: January 07, 2011, 10:18:27 AM »
    Excellent work TT it working for me.......... ;)
