" /> Check state of place. - Genesys CTI User Forum
Author Topic: Check state of place.  (Read 2079 times)
Offline Big Rod
« on: September 02, 2010, 03:47:28 PM »
Odd I know, but we're trying to put in a routing option whereby if the caller knows the extension of the person they want to speak to they can type it into a Stream Manager and be routed to them direct.
However, I want to check that the place/extension is in a ready state before targetting, but we don't have the agents details, just the <extension>@statserver.AP.
Can't find a suitable function but I might be blind.
How'dya think that can be done?
Offline BenTaylor
Re: Check state of place.
« Reply #1 on: September 03, 2010, 09:11:15 AM »
There is a CurrentPlaceState stat.
Category: CurrentState
MainMask:
Objects: Place
Subject: PlaceStatus
Query it with sdata function, route accordingly.
« Last Edit: September 03, 2010, 09:13:27 AM by BenTaylor »
Offline Big Rod
« Reply #2 on: September 03, 2010, 12:15:46 PM »
Thank you!
