" /> where to put the function incrementpriority in the routing strategy? - Genesys CTI User Forum
Author Topic: where to put the function incrementpriority in the routing strategy?  (Read 3832 times)
Offline kevinwang
Hi ,guys,
I want to use the function incrementpriority to dynamically increase the priority of an interaction waiting in the queue,
but I have no idea where to put it? I mean before selection object or after it?
if before selection, interaction is not in the queue yet, but if after selection, how can I change the priority using incrementpriority?
thanks in advance.
Kevin
Re: where to put the function incrementpriority in the routing strategy?
« Reply #1 on: October 20, 2010, 06:41:44 PM »
Hi Kevin,
You must use the IncrementPriority function before the Selection object. Priority is managed by URS and is not directly related to any queue.
Offline kevinwang
« Reply #2 on: October 20, 2010, 08:17:21 PM »
actually, that's what I did, but the priority didn't update as I expected. maybe I need to print the priority in the log to figure it out.
Offline kubikle
« Reply #3 on: October 21, 2010, 10:37:23 PM »
Fragment of URS log (covering some call while waiting) could be useful.
Offline Kevin S
« Reply #4 on: October 29, 2010, 12:09:07 PM »
Since you don't have to specify the queue in the parameters, before the selection object will work fine if your routing has only a single Selection.
I don't think it's required to use the Priority function to "initialize" the priority.
