" /> Stream Manager announcement - PCM file format not played - Genesys CTI User Forum
Author Topic: Stream Manager announcement - PCM file format not played  (Read 3428 times)
Offline New...
« on: November 16, 2010, 09:59:52 AM »
I have a prompt file with audio format PCM and when I use that in Play announcement block - it is not getting played and stream manager log shows 404 not found error.
Any pointers would be helpful.
Thanks.
Offline Timur Karimov
Re: Stream Manager announcement - PCM file format not played
« Reply #1 on: November 16, 2010, 10:52:44 AM »
[quote author=New... link=topic=6015.msg26132#msg26132 date=1289901592]
Thanks.
show you announcement block configuration and corepsonded SM log files.
« Reply #2 on: November 16, 2010, 01:09:01 PM »
Check the SM logs, it will show the specific path and route it is trying to search on
« Reply #3 on: November 16, 2010, 05:08:59 PM »
I would suggest you to check Stream Manager log. It's pretty self-explaining so you should find out why SM can't find your audio file.
PS. Does file name of your audio file have correct suffix (<filename>_<pcma/pcmu>.wav)?
