" /> OfflineWorkType1 Statistic - Genesys CTI User Forum
Author Topic: OfflineWorkType1 Statistic  (Read 2438 times)
Offline PFCCWA
« on: January 11, 2011, 04:00:22 PM »
hello,
Can anyone confirm my thinking on the OfflineWorkType1 statistic?  reading the reporting technical reference, it is suggested this was discontinued in 6.5.
We have been using the TotalHandleTime statistic (specifically in WFM) since probably version 5:
Category=TotalTime
MainMask=CallInbound,CallOutbound,OfflineWorkType1
Objects=Agent, Place, GroupAgents, GroupPlaces
Subject=AgentStatus
However if the offlineworktype1 statistic is discontinued it will not be counting thus making the handletime compromising of just CallInbound and CallOutbound?
I am thinking the MainMask should be CallInbound,CallOutbound,AfterCallWork?
WA
tony
Re: OfflineWorkType1 Statistic
« Reply #1 on: January 18, 2011, 11:34:40 AM »
Hello!
You will need to check a few things, to validate if OfflineWorkType1 is still valid in your environment.  Check your TServer AND StatServer documents for your current version, to see if they are still valid.
If not, ACW is one Stat you could use - but you can also define your own.  A lot of companies have multiple "reasons" for ACW (such as "Lunch", "Break", "Meeting", "Training", etc.) - I'm pretty sure that this topic has been discussed within the Forum - perhaps you could search for it...?
TT
