" /> Request rejected: error code 166(No Stream Managers are defined) - Genesys CTI User Forum
Author Topic: Request rejected: error code 166(No Stream Managers are defined)  (Read 4890 times)
Offline Grum
Hello everybody!
Recently I had to deploy genesys platform on the other servers and everything was deploying well until I began testing calling.
The problem is about Stream Manager.
I did all necessary  - deployed configuration layer, management layer, routing components (ERSDAP, ERSDBServer, URServer, StatServer, IRD) and of course SIP and SM - in general all for testing call and play ann. (except statistic components)
I created simple test strategy included 3 blocks: Entry, Play Announcement, Exit.
And could see such situation - my call entered strategy and ended on block "Play Announcemen" with "Busy".
I started analysing logs and became stymied with such error (code 166) - No Stream Managers are defined.
I checked everything what i could - Stream Manager and SIP options, different connections, VoIP service DN named Treatment and its annex and so on. I even tried to change versions of SM (7.2 <--> 7.6) So my last hope is you, my colleagues! :) Can you help me plz what's wrong I did or maybe what I did not...Hope you will advise me some ideas.
Here is my SIP and SM logs with only 1 test call. As you can see, SM log is without any gestures, strange silent... :(
SIP log [url=http://depositfiles.com/files/gw8nb0sxe] http://depositfiles.com/files/gw8nb0sxe [/url]
SM log [url=http://depositfiles.com/files/syxf38rjf] http://depositfiles.com/files/syxf38rjf [/url]
Sorry for depositfiles, but I couldn't save it as attach
Regards, Grum!
Offline Fra
Re: Request rejected: error code 166(No Stream Managers are defined)
« Reply #1 on: January 19, 2011, 04:23:10 PM »
I can't download the logs from where I am, however, the first thing I would do is look at the VOIP Service DNs Annex tab properties to verify the contact details are fine and cross check them with the Stream Manager application options.
Fra
« Reply #2 on: January 19, 2011, 04:48:04 PM »
Hi Grum,
Please change value of SIP Server's option 'sip-treatments-enabled' to 'true' and try again :)
Offline Grum
« Reply #3 on: January 20, 2011, 08:10:04 AM »
Fra, thank u for attempting advising me, but as I said earlier I already had chacked VoIP Service DN several times)
René, as for You, I have just no words how I thanks for You!!!!!))))You even can't image!) I have tried to solve this problem at about 3 weeks!I realy have broken my brains!)))
You made me unbelievable happy, becourse this promblem became principle for me)so thank u very much for your tenderness!)
so..IT WORKS!!!:)
« Reply #4 on: January 20, 2011, 07:57:20 PM »
René I think you have a fan  ;D
« Reply #5 on: January 21, 2011, 12:18:11 PM »
;D
