" /> config dbserver not starting from services manager - Genesys CTI User Forum
Author Topic: config dbserver not starting from services manager  (Read 2446 times)
Offline k_gen
« on: February 07, 2011, 12:03:49 PM »
Hi, I do not have [lca] section in my dbserver.cfg file. so i added the section as below
[lca]
lcaport=4999
now iam not able to start config dbserver from windows services manager. If I do not have the lca section in dbserver.cfg file then i can start config dbserver. In this case, Iam not able to start/stop properly from SCI.
Have anyone faced this issue. Pls help.
Thanks in advance.
Re: config dbserver not starting from services manager
« Reply #1 on: February 07, 2011, 01:08:44 PM »
And what does logs say?
Independent DBServer or a client for CME?
Offline k_gen
« Reply #2 on: February 07, 2011, 10:01:31 PM »
Config DBServer is installed as independent server.
The Path To Executable property for DBServer service in windows services manager is as shown below.
"C:\Program Files\GCTI\DB Server\multiserver.exe" -service DBServer -cfg
The error I see in the log file is
[b]Mandatory parameter - config server port is not specified[/b]
If I modify the Path To Executable property for DBServer service in windows services manager to as shown below,
"C:\Program Files\GCTI\DB Server\multiserver.exe" -service DBServer -app cfg_dbserver -host gen101 -port 2020
now iam able to start config DBServer properly as an independent server. Iam also able to manage it from SCI.
I thought it was valid to use either [b]-cfg[/b] or [b]-app cfg_dbserver[/b] as iinput parameters for config dbserver. But looks like providing [b]-app cfg_dbserver[/b] is the right thing to do.
