" /> Repeated calls Issue.... - Genesys CTI User Forum
Author Topic: Repeated calls Issue....  (Read 2672 times)
Offline karan
« on: February 11, 2011, 02:11:27 PM »
Hi All,
                We are using genesys 7.5ver, now we are facing the issue like repeated calls through. The agent dispose the call as [b]SWITCH OFF[/b] but the data through to the agent again.  Still we are having fresh data and We are [b]not rechurned[/b] the data then how this is happening.
Advance Thanks to All,
karan..... ;)
Offline Daimonas
  • There's a fish in every bowl.
Re: Repeated calls Issue....
« Reply #1 on: February 14, 2011, 03:28:09 PM »
Hi Karon,
Not familar with this issue, have you opened a ticket with support? What switch are you using? Can you describe the problem in more detail?
Daimonas
