" /> Abandoned calls Reporting Question/Query - Genesys CTI User Forum
Author Topic: Abandoned calls Reporting Question/Query  (Read 3105 times)
Offline PFCCWA
« on: February 11, 2011, 05:28:13 PM »
Has anyone ever reported on callers who abandon either during welcome greetings or in queue, and then subsequently call back another time?
We have a customer who has asked for this level of information to determine the % of callers who ring back having abandoned the initial time.
WA
tony
Re: Abandoned calls Reporting Question/Query
« Reply #1 on: February 12, 2011, 08:24:07 AM »
Hi WA
I think you are (almost) talking about First Call Resolution...? :)
If you have Infomart or a level of reporting which allows you to extract ANI or at least a  level of Customer Data, then it's something you can achieve - otherwise it gets a bit sticky...
Tony
« Last Edit: February 12, 2011, 08:31:45 AM by Tony Tillyer »
Offline smile
« Reply #2 on: February 12, 2011, 11:51:53 AM »
To analyse such "repeated calls" you have to use detailed reporting. This could be interaction concentrator or your own solution which can store ANI and date/time information from IVR/routing strategy into external (custom) database. After that you can prepare request on this db: who called more that ones during e.g. one hour. Is it the actually what you want to know?
