" /> How to acomplish Genesys SNMP Master agent project - Genesys CTI User Forum
Author Topic: How to acomplish Genesys SNMP Master agent project  (Read 10125 times)
Offline GenesysNewbie
« on: March 10, 2011, 03:36:28 PM »
Hi friends,
Due to a project we are looking to implement master agent component. Currently i am working in a test lab, i have installed the Master agent.  The service is started  ...
What i am looking for is a way to verify its working fine before trying to install this solution on production environment. I have downloaded a free tool that works with traps; However i can not see Genesys traps beetwen my client and server.
Example of my problem
If i use my tool (solarwinds )to test a native trap it shows a value ... for example "number of process running on Server = 30" but if use the tool to monitor Genesys mib, the variable seems to be empty. "GenesysHostname = no value is shown"
What i should revirew in order to troubleshoot this issue? Hope somebody can help ...
thnaks in advance
« Last Edit: March 11, 2011, 04:03:30 PM by GenesysNewbie »
tony
Re: How to acomplish Genesys Master agent project
« Reply #1 on: March 11, 2011, 08:22:42 AM »
SNMP Master Agent...
Check[b] trap_host[/b] and [b]trap_target[/b] definitions in the documentation and verify your settings for both of them...
T
Re: How to acomplish Genesys SNMP Master agent project
« Reply #2 on: March 11, 2011, 04:48:39 PM »
Hi dude, thanks for recomnnedation
BTW, i find trap_target, i could not find trap_host under manuals.
What type of parameter is this?
Thanks!
tony
« Reply #3 on: March 11, 2011, 07:44:42 PM »
[quote author=GenesysNewbie link=topic=6240.msg27166#msg27166 date=1299862119]
Thanks!
Sorry - forgot to ask what version you are running..?
TT
« Reply #4 on: March 12, 2011, 04:12:16 AM »
Ok.
7.6 SNMP master agent
7.2 SCS
Tip.
i am filling trap_target in this way = 192.168.1.5/161:public
Any idea?
Thanks!
tony
« Reply #5 on: March 12, 2011, 02:20:30 PM »
If you were using an earlier version (6.x) [b] trap_host[/b] was defined as the Host to which the Master Agent SNMP sends the traps to.  Later versions 7.x)  use the option [b]trap_target [/b]which can define any number of Hosts to send traps to - it is a comma seperated list, applied to the SNMP Application in CIM/CME.
It seems as though your's is configured in the correct syntax (<host name>/<port number>:<community name> ), so that is not the problem.
I would suggest that you look at your "solarwinds" application and make sure that it is correctly configured against the Genesys Host/mib, since that is more likely to be where your error is.
Hope this helps?
TT
« Reply #6 on: March 12, 2011, 04:59:44 PM »
Hi Tony i am getting a message from test app (solarwinds). OID is not supported.
Do you know if there is other app i could perform mastergent testing ?
tony
« Reply #7 on: March 12, 2011, 07:51:44 PM »
I haven't had my hands on any - perhaps...
HP OpenView
http://www.plixer.com/
Offline thinkb4umail
« Reply #8 on: March 15, 2011, 07:10:19 PM »
I use this tool and it works good for me...
http://www.manageengine.com/products/oputils/snmp-tools.html
You need to identify the OID for the processes running on genesys boxes.
« Reply #9 on: March 15, 2011, 07:19:44 PM »
Hi thinkb4umail
Which version of genesys  are you handling?
thanks
« Reply #10 on: March 21, 2011, 06:44:27 PM »
Hi thinkb4umail,
You talk about identifying the OID for the processes running on genesys boxes.
What do you mean sir?
I cannot see genesys traps, i am also uploading a screenshot
Javier
