" /> Call monitoring, Silent, Whisper, Barge - Genesys CTI User Forum
Author Topic: Call monitoring, Silent, Whisper, Barge  (Read 3798 times)
Offline David Waddington
« on: March 22, 2011, 05:14:10 PM »
we are having a problem with this.  We can get it to work, but in all cases:
Screen pop was still very slow for the supervisor unless skills matched the agent.  30 secs +.  With skills matched it is 3-4 secs.
A customer cannot be retrieved (by the agent) after being put on hold.  When retrieve is attempted the call remains open, but the agent loses it – the customer and the supervisor remain connected.  What seems wrong with this is that it suggests that these functions cannot be used in a live situation, as using hold is a commonplace event.
Have we missed a simple parameter here?  Anyone else using these live and not dropping customer - agent connection?
Re: Call monitoring, Silent, Whisper, Barge
« Reply #1 on: March 22, 2011, 06:42:38 PM »
Hi David,
[quote]Screen pop was still very slow for the supervisor unless skills matched the agent.  30 secs +.  With skills matched it is 3-4 secs.[/quote]
I don't see any relation between mentioned features (call monitoring) and screen-pop. I think you should check your agent desktop application if screen pop-up takes so long.
[quote]A customer cannot be retrieved (by the agent) after being put on hold.  When retrieve is attempted the call remains open, but the agent loses it – the customer and the supervisor remain connected.  What seems wrong with this is that it suggests that these functions cannot be used in a live situation, as using hold is a commonplace event.[/quote]
I think I've already heard about similar issue but not 100 % sure. Can you upload your SIP Server log so I can see what happens to the call?
« Reply #2 on: March 24, 2011, 12:51:14 PM »
Rene,
I can't seem to post the log in the message body - is there a restriction on size?
Is there some other way to get it to you?
David
« Reply #3 on: March 28, 2011, 05:54:15 PM »
Hi David,
Unfortunately, upload functionality is disabled on this forum. Please upload the logs somewhere and post the link here.
PS. To Admins - guys, are you going to fix upload in near feature? ;)
