" /> Assigning CPD ports to specific campaigns - Genesys CTI User Forum
Author Topic: Assigning CPD ports to specific campaigns  (Read 3447 times)
Offline scoll7567
« on: March 25, 2011, 11:43:23 PM »
We have 70 CPD ports used for outbound calling.  We have two campaigns sharing the 70 ports.  Is there a way to assign/allocate specific ports to a specific campaign (e.g., CPDs 1 - 30 to campaign 1 and CPDs 31 - 60 to campaign 2)?
We use progressive dialing for both campaigns
Offline Dionysis
Re: Assigning CPD ports to specific campaigns
« Reply #1 on: March 27, 2011, 10:39:52 AM »
You can't allocate specific ports, but you can restrict the number of ports a campaign group uses.
Offline scoll7567
« Reply #2 on: March 27, 2011, 05:06:55 PM »
That is what I thought
Offline kinjiru
« Reply #3 on: March 28, 2011, 03:16:01 AM »
One option, which I admit is ugly, is to have multiple CPD servers (with each server having the specific ports you want - e.g. 1-30 ports in CPDServer1, 31-70 in CPDServer2).
Then point each campaign to a specific CPD Server.
You run into constraints around breaking up your ports per CPD Server since depending on what you are using, it may not be physically possible.  E.g. you might have 1 x 60 port Dialogic card for CPD.  You can't break that into two.
