" /> Supervised transfer to RP on Alcatel OXE - Genesys CTI User Forum
Author Topic: Supervised transfer to RP on Alcatel OXE  (Read 3959 times)
Offline OXE_4400
« on: June 01, 2011, 12:29:14 PM »
First agent answer incoming call from first Routing Point and dials number of second RP for supervised transfer.
Genesys routes call to second agent ( from second RP ) only on first agent disconnection ( end of transfer ).
It looks that Genesys starts strategy only after first agent disconnection, before it enquiry call stays in not clear state.
I want to startup strategy on second RP immediately after second RP number dialing and inform first agent does anyone agent is able to answer transfered call => some busy tone if no one ready agent, anything else in case of min 1 ready agent.
I have tried to manage OXE parameter RSI SUPERVISED TRANSFER, also Tserver parameter rsi-report-xfer (true).
Re: Supervised transfer to RP on Alcatel OXE
« Reply #1 on: June 01, 2011, 02:37:52 PM »
on which RSI are you setting the Supervised transfer option?
What is the value for URS route_consult_call option?
« Last Edit: June 01, 2011, 02:53:52 PM by cavagnaro »
Offline malhelo
« Reply #2 on: June 19, 2011, 08:53:18 AM »
do you have logs for your case in oredr to help?
regards
Offline OXE_4400
« Reply #3 on: July 11, 2011, 01:28:12 PM »
[quote author=cavagnaro link=topic=6457.msg28077#msg28077 date=1306939072]
everything OK after URS route_consult_call option changing to true.
Thanks.
