" /> VB CODE TO MAKE CELLS FLASH IN CC PULSE - Genesys CTI User Forum
Author Topic: VB CODE TO MAKE CELLS FLASH IN CC PULSE  (Read 4498 times)
Offline Ghost
« on: July 18, 2011, 02:51:48 PM »
Hi
Does anyone have the VB code required to make the cells flash in CC PUlse when thresholds are reached?  Would be very grateful if you could let me have a copy  ;D
Offline Tambo
Re: VB CODE TO MAKE CELLS FLASH IN CC PULSE
« Reply #1 on: July 22, 2011, 10:49:25 AM »
why does it need to flash ??? is bright red not visible enough for when thresholds are breached?  ???
Offline Ghost
« Reply #2 on: July 22, 2011, 10:51:23 AM »
I thought that bright red would be enough, although this is one of the many strange requests I get?  I know it is possible will have to take time away and design something I think.  Cheers
Offline Tambo
« Reply #3 on: July 22, 2011, 02:28:33 PM »
I made the rookie mistake of mentioning the flashing colours and have been asked to look into it too  :-[
If I come up with something i'll post it, if you come up with something can you?
Offline Ghost
« Reply #4 on: July 22, 2011, 02:45:53 PM »
;D will do  ;D
Offline toby
« Reply #5 on: July 31, 2011, 04:51:59 AM »
This is not a clean blink and you would need to modify it to suit the selected metric to make sure the 3 seconds works well with your update frequency etc. but, its a rough idea if you are desperate enough for it.
[font=courier]if Threshold.StatValue = StatAction.SDNALoggedOut then
    if Second(Now()) Mod 3 > 0 then
        Threshold.Result = true
    else
        Threshold.Result = false
    end if
end if[/font]
Offline Anth
« Reply #6 on: August 01, 2011, 07:23:04 AM »
cool,
ill have a play with that one today
Offline Ghost
« Reply #7 on: August 01, 2011, 08:04:54 AM »
Cool, thanks for that will have a go later today  ;D ;D
