" /> Record calls waiting into DB - Genesys CTI User Forum
Author Topic: Record calls waiting into DB  (Read 2877 times)
Offline Mohammed_Adel
« on: July 26, 2011, 11:09:31 AM »
Dears
i need to know away to record waiting calls on a virtual queue in order to have historical data for these calls
awaiting your feedback
BR,
Mohammed Adel
Offline Tambo
Re: Record calls waiting into DB
« Reply #1 on: July 26, 2011, 12:56:59 PM »
what do you mean record ?? and what historical data are you needing?
Tambo
« Reply #2 on: July 28, 2011, 01:12:36 PM »
we have an issue as number of calls waiting raises however agent are ready to receive calls
we have CC Analyzer for historical reporting
all i need to insert waiting calls with their attached data(skill , VQ , ...) into a DB in order to have detailed investigation
is it doable ?
Offline Tambo
« Reply #3 on: July 28, 2011, 08:53:38 PM »
the logs will show the issues that you have but.......you need to look at the issue for your VQs not delivering to agents. have you copied them from excel? there might be an issue there, delete them then input them again one by one in both CME and in LRT
Tambo
