" /> AHT (Avg Handle Time) at Queue level - Genesys CTI User Forum
Author Topic: AHT (Avg Handle Time) at Queue level  (Read 5452 times)
Offline CTIgem
« on: July 28, 2011, 07:55:42 PM »
Is anyone out there doing AHT at Queue level with Tserver 8.x?
Got stat definition from genesys solution site but seems not working.
Thanks.
Offline Tambo
Re: AHT (Avg Handle Time) at Queue level
« Reply #1 on: July 28, 2011, 08:50:19 PM »
surely AHT has to be at agent level? how can it be done at queue level?
Offline rpenney
« Reply #2 on: July 28, 2011, 10:08:45 PM »
Do you have the VQs added to the Agent Group as Origination DNs?
You need to do this to tie together the Agent Group with the Queue so the AHT calculations work correctly.
Offline CTIgem
« Reply #3 on: July 29, 2011, 01:38:30 PM »
Thanks, rpenney.
How do you deal with agent belonging multiple groups?
Offline CTIgem
« Reply #4 on: July 29, 2011, 01:54:05 PM »
Never mind my question.
I think it is working now.
thanks.
Offline CTIgem
« Reply #5 on: August 01, 2011, 07:30:54 PM »
Rpenny,
What are the call conditions that might give higher handle number than queue entered?
In production, call entered into queue doesn't match with calls handled.
Thanks in advance.
Offline rpenney
« Reply #6 on: August 05, 2011, 08:35:26 AM »
Off the top of my head,
[list]
[li]Ring No Answer I think causes the call to be counted twice[/li]
[li]Transfers depending on how they are performed (i.e. through the VQ or not)[/li]
[li]Direct calls to agents[/li]
[li]Outbound calls (maybe)[/li]
[/list]
There are a lot of factors that go into this. I probably can't help much more without knowing a lot more about your environment and setup.
Offline CTIgem
« Reply #7 on: August 05, 2011, 01:44:11 PM »
Thanks.
Found a good explanation from tech site.
