" /> Synchronization of ICON 7.5 for CFG data not working. - Genesys CTI User Forum
Author Topic: Synchronization of ICON 7.5 for CFG data not working.  (Read 2759 times)
Offline longcao
« on: August 05, 2011, 12:34:11 PM »
Synchronization of ICON 7.5 for CFG data not working, but it works for update of cfg data.
for 7.6, there is start-cfg-sync option for cfg data synchronization purpose, for 7.5 ,how to invoke the initial synchronization for CFG Data?
Thanks.
Offline Allan
Re: Synchronization of ICON 7.5 for CFG data not working.
« Reply #1 on: August 10, 2011, 03:56:08 PM »
First set start-cfg-sync to -1, apply,  (this step is not in the documnentation)
then 0 apply,
finally 1 apply
That should do it.
If it does not do it then restart Icon Cfg and that will also  reload the config.
regards
Allan
