" /> ist of Hard phones from different vendors which are support with the SIP Version - Genesys CTI User Forum
Author Topic: ist of Hard phones from different vendors which are support with the SIP Version  (Read 2797 times)
Offline ramanjs
Hello
Can you please provide me the list of Hard phones from different vendors which are support with the SIP Version 8.0
Raman
Offline Steve
I suggest you read the Genesys documentation. There is a supported media document although I don't know if this is covered. Otherwise speak to Genesys see what they recommend, as they will ultimately have to support your solution.
Offline ramanjs
Hello Steve
I have checked the Genesys Documentation but didn't find any thing about the Hardphone support
Can anyone like to add something to this Query
I will be thankful of him
raman
Offline borkokrz
Check Supported Media Interfaces - Table 12. SIP Server Support.
Offline ramanjs
Thanks for the reply
Raman
