" /> Problem Reading UUI data within Foxpro - Genesys CTI User Forum
Author Topic: Problem Reading UUI data within Foxpro  (Read 3507 times)
Robert Howard
I am trying to read some uui data attached with our IVR with foxpro using the activex toolkit for 5.1. I can see the UU_DATA in the TSERVER log files but I cannot see the data with the FOXPRO application. Any help would be greatly apprciated.
Robert
Marked as best answer by on August 03, 2025, 03:59:13 AM
KM
  • Undo Best Answer
  • What function are you using to read it?
    Robert Howard
    I guess that is the main question. I can't figure out what function to use.
