" /> WFM Web Services Error - Genesys CTI User Forum
Author Topic: WFM Web Services Error  (Read 4045 times)
Offline RDB
« on: September 07, 2011, 08:34:16 AM »
When I am trying to login to WFM Web Services, its giving me an error stating "[b]Cannot connect to WFM Server[/b]"(please see the screenshot attached), inspite of every WFM component being up and running.
The error code its giving is [b]INIT-1[/b]. Couldnt find anything
related.
Also, I did a check on all the required configuration and it seemed ok.
Would appreciate any inputs on this.
Thanks.
Offline fnunezsa
Re: WFM Web Services Error
« Reply #1 on: September 07, 2011, 07:35:51 PM »
Are you sure the WFM Web application is pointing to the correct Configuration Server?
Check ConfigServer.properties file under WEB-INF folder
Offline RDB
« Reply #2 on: September 08, 2011, 10:34:28 AM »
Which location and component you are referring to?
Offline fnunezsa
« Reply #3 on: September 08, 2011, 05:13:48 PM »
I'm referring to WFM Web component. It is a Tomcat or Websphere based Web Service. You should have a "wfm" folder and beneath that you should have WEB-INF folder and then the ConfigServer.properties file. Not sure about the exact folder-subfolder structure, though.
You may always search for ConfigServer.properties using your OS search functionalities.
Offline RDB
« Reply #4 on: September 09, 2011, 04:25:14 AM »
Bingo fnunezsa, you got it.
the ConfigServer.properties file was not updated with the ConfigServer Details.
The WFM Web is working now after updating the file.
Just wondering why Genesys does not mention these things at the right place or
it was me who missed it. I dont remember the mention of updating the
ConfigServer.properties file anywhere when installing WFM Web.
Thanks for all the help.
Offline fnunezsa
« Reply #5 on: September 09, 2011, 09:57:16 PM »
As far as I remember the information stored in ConfigServer.properties is gathered by the WFM Web installation Wizard.
