" /> Deepen GPlus adapter knowlege: Variables propagation - Genesys CTI User Forum
Author Topic: Deepen GPlus adapter knowlege: Variables propagation  (Read 3001 times)
Offline Gef Buneri
  • Madness is just a point of view.
« on: February 17, 2012, 02:22:08 PM »
Hi all again.
As any of you already understood, I'm getting in touch with an already existing system I'm tring to understand as better as I can. Now it's the turn of the GPlus adapter. In my configuration:
H.323, Gplus_Comm_Server_for_SiebelCRM (7.2), TServer (7.5), urs_messageserver (7.1), URS 7.5
The adapter it's actually used to propagate some variables from IRD applications to Siebel CRM using AttachData: Caller, TimeOut value for time based frontend services to show a timer with residual time on CRM GUI, etc. I want to locate where this variables are to be set. i.e. if I want to propagate a new variable must configure something in GVP side or must Siebel CRM developers configure something by their side, to receive the new variable ? I gave a look to involved applications in CME, but I didn't found no clue to answer this question.
Regards.
Re: Deepen GPlus adapter knowlege: Variables propagation
« Reply #1 on: February 21, 2012, 08:58:46 AM »
Hi Gef,
Gplus adapter receives all User Data attached to the call (out-of-box functionality) and configuration what parameters will be used/shown is done on Siebel CRM side.
Offline Gef Buneri
« Reply #2 on: February 22, 2012, 10:22:49 AM »
Thank you very much, René. I'll ask our CRM staff to build up some test scenarios.
Regards.
